Humvee 24 bolts o-ring size
Enforced_Leo44
78
Parma, Italy
After a unhealthy amount of research here in Italy, I finally found somebody with a set of 24bolt rims
I'm now looking for a set of o-rings, searched for the original ones and they seem to be at around 20$ or more per piece
So if anyone has the actual sizes/numbers of the oring, I'd be very glad to try to find a substitute or even make my own with the right size rubber stock
Thanks in advance for any info!
Mogman
9,694
Papalote, TX
Others may have some good sources but the only ones I have had luck with are the factory OEM ones from AMG or one of their vendors.
I have tried several "aftermarket" ones and none have worked.
If the original ones are not damaged they can be re-used.
When you consider how much work is involved $20 ea is a bargain
Tiwaz
39
Miami Beach
How much did you pay in Italy for those 24 bolts rims...?
