B8136sx2196
- 19
- 3
- Corsicana Texas
Swapped around relays. Used dioxide. Switch Is good. I did try jumping across the starter to take the switch out of equation. Same thing happens. As soon as the starter engages the display goes blank and show to be rebooting. It will run 5-7 seconds and die. The generator makes voltage within a second of two of running. Checked between L2 and L3.
Now if I hit the battle short right after it starts to run and turn it off as soon as the display comes back up the engine will stay running. Then if I leave the unit running for an hour or two then turn it off it will restart like it should with NO use of the battle short. (normal cranking procedure).
Is the an internal battery somewhere that is charged when I let the unit run for a couple of hours and then discharges itself by the next day? A bad diode ?
all I know is if the display turns off during the cranking procedure it will die. If it doesn’t it will run just fine.
