Jdj211
- 19
- 3
- Houston, TX
I haven’t even gotten to the point of hooking up the aux tank yet. The issue is that when I turn the switch to the prime/aux/run position from the prime/run position the entire set shuts down as if it had been turned to the off position.How full is your primary fuel tank? Aux fuel pump should only start running when your primary is down to 1/4 tank, and shut off when it gets to 3/4 tank. Is the aux line clear and hooked up properly at both ends?
I understand that the aux fuel pump won’t run until the day tank is around 1/4, but I can’t even keep the set running with the aux mode active to see when it cuts on/off.
