- 744
- 1,381
- 93
- Mesa, Colorado
I have an account so easily purchased. I need one of those sandwich packers too. The hoe needs regrease every 25-50 hours, 32 zerks, same with the track loader but only 20 on that. So I go thru a 5 gallon lithium grease bucket fast with the pressure pump.The Amsoil grease I use is a calcium sulfonate complex rather than a lithium complex. The calcium sulfonate has a dropping point of 315 degrees vs the lithium complex of 260 degrees. It also has greater shear stability, better water resistance, and higher pressure protection. It's better in every way actually - the only way lithium is better is cost - it's half the price. But you can do all the wheel bearings with a single $12 tube of Amsoil so there's really zero reason to use the inferior lithium complex grease - well there's 6 reasons I guess. And all six of those won't satisfy you at McDonalds.
NLGI grade is just a measurement of thickness. The Amsoil waterproof grease is also NLGI #2.
