Has anyone installed a cooling system upgrade?
deank
384
Florida
I have been researching a cooling system upgrade by paradox by design. Has anyone here used it? Would you recommend it? My M1031 only has 16 k miles and I want to make it last as long as I can.
Thanks for any feedback!
Dean
antennaclimber
950
State College, PA
I have one of the kits on my M1008. Some people think it's not needed and others think it would be a good idea. My thought it's worth a try and would only be beneficial given the history of these engines with blocks and or heads failing.
I do not have any data as to it being better or worse than the stock system. The truck has been driven across the USA two and a half times without any issues.
The radiator is a aluminum and plastic unit, I have driven it thru some extreme heat conditions towing a M101A2 trailer and so far, no issues.
2INSANE
824
Belgrade, Montana
My personal testing on running 6.2 and 6.5 motors on an engine stand shows that they all get hot in the rear of the motor. I recently installed the PBD kit on a customers motor and can confirm that the kit does balance the temperatures better on the motor. I would say this kit is now a MUST HAVE UPGRADE for any 6.2 and 6.5 motor. Here are pictures.
deank
384
Florida
Thank you for the input and the pictures. I am convinced I should do this now.
ballencd
78
Columbus, NC
I agree its a good idea but that's a pretty pricey modification. Seems you could do it with $80-100 in parts DIY style. Is that a Hummer crossover in the pictures?
2INSANE
824
Belgrade, Montana
No it is a coolant crossover from a 93 GMC 1ton I parted out. Pictured is a hummer coolant crossover.
2Insane, how did you determine your motors were running hot in the rear? Did you take measurements?
I used a laser thermometer gun while the motors were running on an engine stand. Temperatures averaged 10-20 degrees hotter in the rear of the heads or around cylinders 7-8. That is why the piston clearance for cylinders 7-8 are meant to be wider. See pic.
Now imagine the motor up against the firewall building even more heat. The temp sensor is more toward the cooler side of the motor so if your gauge says 200 degrees, it will actually be 210-220 in the rear. Maybe more! Now imagine your pulling a big hill and your gauge says you are overheating at 220-240 degrees… Your actual temperature in the rear will be 230-260 Degrees! Now think of the history of the 6.2 and 6.5 cracking head problems over the years… Here is the reason!
Edit: No I am not getting sponsored or paid by paradoxbydesign to say these things. I am a normal bloke just like you that loves these old squares and motors!
deank
384
Florida
Getting closer to putting the engine back in the truck. I have installed the PBD cooling upgrade. Being that mine is an M1031 , i ran the hoses along the edge of the drivers side head and had them come out below the thermostat housing. I have ordered 2 each 90 degree elbows so I can connect to the Y-block.
2INSANE
824
Belgrade, Montana
It looks like you have the 90 degree elbow on in the wrong position. It should be pointing up and the hoses run over the plenum.
check this out. Post 218
deank
384
Florida
Some progress today. The new 90 degree fittings came in today.
view from passenger side front
View from driver’s side front
view from below
79Vette
119
Los Angeles/CA
In my opinion based on testing with my engine, this type of cooling modification is a waste of time and money.
I can't speak for others engines or applications, but in my turbo 6.2 I have digital gauges with RTD type coolant temp sensors in the factory location in the front of the driver side head, in the glow plug thermistor port in the rear of the driver side head, in the radiator inlet hose, and the radiator outlet hose. The front and rear of the driver side head are within 10 degrees at all engine operating conditions and usually within 5 degrees. The rear sensor is almost always cooler, indicating more flow is not needed at that location.
I've swapped the gauges and sender probes around between all locations and these results are consistent. In my engine, based on testing and data there is no reason to modify the cooling flow path specified by the engine designers and built into the cylinder block.
