tgtaylor64
- 4
- 18
- Florence, SC
Working on a 1985 CUCV for a friend. PO converted to 12 volt. Wiring left intact. Converted it back to 24 volt and changed the starter. Cranks fine; no issues. However, only the rear battery is charging (14.7 VDC). I have two alternators that I have had tested good to switch out on the drivers side. I am getting 55 VDC out of either one that I have on the drivers side. No charging of the front battery. Dash volt meter showing in the yellow. Gen 1 light on. I have traced every wire and tested resistance on every charging circuit wire listed but cannot figure this one out. Front battery is new Diehard. I must figure this out in the next week as the vehicle is being shipped to Germany.
