dherman304
- 53
- 18
- Texas, DFW
Well, finally got all of the chores done on HMMWV went to take it for a test drive and accidentally ran over my hi-lift jack, I put it in drive to move over the jack but I heard sparks and looked forward to see sparks and smoke coming from somewhere behind the "dash" (seemed to be coming from above and a little left of the steering column). I turned the truck off waited of the smoke to clear and tried to start it to find no "Wait" or "Brake" indicator working, and it didnt try to turn over. All other lights seem to work in the truck (gauge cluster etc.)
I took everthing off the dash and cant find any obvious signs of a short. I have +24v coming into and leaving the ignition. I checked the 14B wire going into the Smart Box and it has continutity with the ignition wire (when in nuetral).
There could be damage inside the box but that doesnt explain why I saw sparks behind the dash. If it was from the smart box I would have expected the sparks to be more in the footwell.
I know troubleshooting electrical problems is nearly impossible over the internet but Im hoping that someone knows about a wire or somewthing in that area I cant see that could be causing this issue.
