What is the substance on the inside of the Hummer/other tires?
Special T
21
Wetside/ WA
I tried looking through the TMs but couldnt find anything. Does anyone know the answer?
I have the high suspicion that it is your standard tire lube Likel Murphy's tire lube or something of that nature. I have seen Hummer tires with the yellow grease like color when a tire is near new and it really black when run. Ive mostly noticed it on Hummer tires, and 1200r20 that come off the stryker platform. Im guessing its the coolant/lube incase the tire deflates and rubs on the run flat.... Does anyone know where the MSDS sheet for this stuff can be found?
KansasBobcat
9
San Antonio, TX
My old -34 says: Lubricant, runflat assembly, use with radial tire part number 89307-2. You might try searching for that and MSDS sheet. It comes out pretty well with Dawn soap and warm water. You are correct, the packet ruptures when runflat contacts tire and reduces friction to keep temp down.
Retiredwarhorses
4,409
Brentwood, Calif
Run flat lube....a packet goes in each tire...this is so you don't destroy the run flat if you run on them.
i never put it in....that stuff is a mess.
DatGuyC
22
Essex, Maryland
I just broke down one of my tires to move it around the wheel to help it balance. That black goop was everywhere, got everywhere, and is a general pain in the butt.
Special T
21
Wetside/ WA
Well its supposed to help not damage the tire at 30mph for 30 miles. Some of you say it comes in a packet and i found that its also obtained in a 55 gal drum. Nearly new tires i have seen with it in the tire looks like it was put in the center of the tread (inside) with an industrial caulking gun. I have found that just water is necessary to clean it up, but ot water works better. It is water soluble. Golden eagle I dont need any but a Pic of the package or manufacture name on it would be great.
NMDMFG
florida
Here it is. Comes with o-ring, and new nuts for the rims.
I am looking for a large quantity of this stuff can you quote me or point me in the right direction? Also can you email me back at govt@defensess.com not sure if I will get notified on the forum
thanks
PN: 89307-2
PN:12339497
DSC:LUBRICANT RUNFLAT
QTY:353 EA
NSN:2640-01-262-9517
END ITEM:M998
Mogman
10,180
Papalote, TX
thanks
PN: 89307-2
PN:12339497
QTY:353 EA
END ITEM:M998
Welcome to the SS forums, resurrecting a 9 year old thread :oops:
