- 767
- 1,412
- 93
- Mesa, Colorado
Food for thought.
Over 49 calendar days, the A1 overall work done was as follows ...
- new oil pump #496-4800 & pan gasket
- Oil cooler decking +gaskets
- Bypass valve springs/orings(2)
- New trans cooler lines/orbs (2)
- New Trans cooler bracket
- ECM upgrade 330hp
- New fuel lines (6)/orings
- Amsoil Bypass filter 2um
- New compressor
- New PS pump & tube
- New exhaust (vertical) + wraps & shields
- Oil psi test port & gauge
- New water temp sender
- New oil line (compressor)
- New ExBrake air line
- New coolant lines (2) (compr)
- New driveshaft U-joints (4) & balancing
- New serpentine belt (807 0 8 )
- New atmosphere sensor -6722
- New Amsoil Synthetic 15w-40, 34quarts
- New Napa ATF Synthetic Dex6 10 gallons + flush
- New Napa Coolant 50/50 11 gallons
- New fuel/water separator filter + bypass valve cleaning
- New oil pressure test gauge
- New oil pressure sender
- New cab grounds
Exhaust cost: $1,275
Engine & Drivetrain cost: $8,428
Total: $9,703
Steel for all the brackets and exhaust mast was surplus from auction.
Total hours were not recorded but about 2-3 hrs per day on average for the 49 days so 122.5 hours estimated. Welding and cutting gases not included. My mental health costs not included. 🫠
(I wonder what Midwest would charge for all that? )
- ECM upgrade 330hp
- New compressor
- New cab grounds
Total: $9,703
