- 5,367
- 3,378
- Lexington, South Carolina
Just ordered a replacement manhole cover lid for my Highlands model TRL2000 600 gallon fuel pod. I have a type 1 manhole cover on it now, but the lock casting is broken and it can't be locked. The type 2 cover has the lock through two stainless steel plates instead of the aluminum casting.
Type 1 part number is FX1097SA
Type 2 part number is 887-L-541 - I'm upgrading to this type
Available from Clay & Bailey Mfg.
Kansas City, MO
phone 800-821-6583
If you have one, it's probably a good idea to replace the gasket on the emergency flush valve - the original is cork/buna-N (but is probably just cork left and it will leak. I'm replacing mine with a Viton gasket, inside dia 6 inches, outside dia 7.25 inches, 1/8 thick. The six bolts are 1/2 inch, so for an easy fit the gasket holes should be 9/16 according to my gasket man.
The TM is - TM 10-4930-220-13&P if you didn't know already.
Kansas City, MO
phone 800-821-6583
