Enforced_Leo44
- 76
- 28
- Parma, Italy
Hey everyone, quick question
I have a '85 M1008, 6.2 diesel, I need to replace the thermostat gasket and housing because it has a pretty noticeable leak, and while I'm in there I'll replace the thermostat as well.
The thermostat that it's currently on is a "standard" type, and so is the one i bought (Motorad 2006180, 180F opening temp), but I did some research and found out that the OEM replacement should be a AC Delco 13255, which is a balanced sleeve thermostat.
The question is, does it matter which kind of thermostat I use, as long as it has the correct opening temp or does the balanced sleeve make a significant impact and the lack of it might be the cause of the leak?
thanks in advance,
Leo
thanks in advance,
Leo
