Tailgate Hinges
Jinx
Buy me a Coke
161
Gainesville, Florida
Hi all.
I want to swap a nicer tailgate from a junker HMMWV to my running M1114. Both trucks have similar tailgates with hinges bolted to the frame. Two of the bolts and nuts on each side are easy to access. The third's nut is covered by body a bushing and blocked by angled metal. Feeling around it seems like the body bushing needs to be removed to access the last nut.
Would removing the hinge pin be easier? I'm assuming it's removed just like a hinge pin on a house door. Are these pins reuseable or will I need to replace it?
Mogman
9,583
Papalote, TX
I have swapped a couple tail gates and never had an issue with getting to the nuts on the back side, challenge yes but not impossible.
Of course removing the body mounts is no big deal ether, I personally would go that route before trying to drive the pins out.
Jinx
Buy me a Coke
161
Okay, thanks.
Once I get it off it may be a good time to test my rivnut tool and make it easier to replace in the future.
Mogman
9,583
Papalote, TX
Okay, thanks.
That would be one way to go, but just remember rivnuts do not provide as much structural integrity as a nut and washer and you would need flush fitting rivnuts and taper the hole so the hinge fits flush against the body.
Jinx
Buy me a Coke
161
The tailgate currently has shims so it probably wouldn't need to be flush, but I agree I wouldn't be as structurally sturdy.
If I can get to the third bolt to remove it, I should be able to put it back on so that's what I'll do.
Thanks for your help.
Retiredwarhorses
4,181
Brentwood, Calif
You are doing something wrong, cuz I remove a TG a week…and no, you need the shims, they aren’t for looks, they allow the TG to
close properly and align to insert the hooks. Rivnut can’t support weight, the current nut is a stover lock nut, so when you put them back on, just use a regular nut and a small 1/4in impact driver.
Atchuuu
104
MS
Just did this a couple days ago. Look from underneath and you will see where you can insert a socket on an extension right next to the bushing. After I did the first one I was able to do the second side without getting under the truck
Atchuuu
104
MS
Oops- see this was a month ago
Jinx
Buy me a Coke
161
Yeah, I followed the previous instructions and got the tailgate off without much fuss. The only problem was one side had short bolts and the other side was longer, necessitating a deep socket to grab the nut.
Next step is to remove the muffler. TM's say I'll need to disconnect the driveline.
