Will cheap Harbor Freight tire balancer fit center hub of 2-piece rims.
TOBASH
3,488
Brooklyn, NY
Want to do a rough balance of rims.
Will the Harbor Freight bubble balancer fill the center area properly to allow for balance?
Will the Harbor Freight survive balancing 165lb. Wheels?
I searched but no love.
TOBASH
3,488
Brooklyn, NY
Just what I needed to know. Thanks!
Looks like I will need to make an adapter from 1/4” flat stock plate.
I’ll plasma cut two rings and weld together.
Upper ring inner DM 4”. Outer ring upper DM 4.6”. Lower baseplate ring inner DM 4” with outer DM 6”
Thunderbirds
376
Northern Black Hills South Dakota
Still begs the question if the balancer will hold the weight...
According to the owners manual on HF, the balancers' capacity is 15" light truck... Probably a huge difference to the 37" with runflats. Just MHO.
But, if you do move forward, keep the board up to date.
swbradley1
Modertator
1,759
Dayton, OH
Well there goes the plan to balance the 395s on my M915A1.
