Eastern Front
- 9
- 3
- Mobile AL
I know what you mean. I think the part I remembered was once it gets up there you have to lower the chain hoist some so it isn't under tension, hopefully I won't need to deal with it in the future. I brought all the tools I need to do it should that happen.Yeah, Wes makes it look easy by himself but in the case of a roadside tire change I've been thinking of carrying a pop out sign similar to the 'wet floor' signs you see but offering cash for some extra muscle to entice someone to stop and help
.First trip went well. 150 miles and truck did great. I have a leaking gasket for the air dryer, need backup and bed lights installed, Methanol kit needed installing, painting frame, and coolant hose fix. My coolant hose adapter from 2.5" to 2" had some leaks with the alumium flange adapter so I had to adjust it some.
Overall I'm pleased with performance. Definitely a power loss with the 16r20s but it looks good with them on the truck.
As I was about 20 miles from home I was at a stop light and smelled a strong smell of diesel. Decided to keep driving and got it home and sure enough, looks like the injection pump seals have gone. There was some decent drips coming from the pump.
Before I go and use the search Bar, pt pump just unbolts and bolts on right? I don't mess with timing on these pumps I believe? I'm calling premco to see what they would recommend but plan is to have one rebuilt so it's good as new. I'll do some more investigating to make sure it's the pump but I'm 98% sure it's the cause.
Doesn't surprise me, truck is just shy of 40 years old, time for a refresh anyway. In the meantime I have some stuff to work on while I wait on the pt pump.
Does anyone have any photos of their rig they'd like to post up on here?
.Since Memorial Day I have gotten to take Brutus to 2 car shows. I also made it to the 4th of July Parade today.
I had an alternator issue. The one I put on started to fail with 500 miles on it. Got a new one from Napa this time. So far so good. I also got the methanol kit installed. My buddy helped me with it. Don't notice any power gain or egt temp differences. I'm only using a 3gph nozzle. Will look at increasing the size of the nozzle. Before I do that I will turbo the truck.
I also got a fuel button #27 from premco. The engine originally was shipped with a 30. When taking out the idle plunger, there was a 32 in there. So either the pump was rebuilt and someone put a smaller one in or someone swapped the pump out for another one. Going from a 32 to a 27 was a nice fuel bump. Little more power was a nice increase to see. When I do the turbo I'll play around with a different fuel button. So far truck is running great. Next step is to add the sound bar for the cab and I'm also dropping the trans pan to replace the filter and gasket.
Installed the new air dryer. Works great. No issues.
My nephew is obsessed with the "big truck." Everytime he comes down he runs to the garage. Gotta start em young.
I know very well Brutus is a guntruck from Vietnam. I wanted a m54a2 but couldn't find one. This is not an attempt to do the same thing with a 900 series. I just liked the name and felt it was fitting.And I am curious if you know about the “real” brutus?
Any nam vet that was on hiway 1 in the day knows about
brutus.
Not to bash what you have done, you are doing great things... With regards to the fuel filters, you might want to look at the RACOR filters, they are the best out there and they have a clear bowl here is an example: https://www.ebay.com/itm/296679640630?_nkw=racor+diesel+fuel+filter+water+separator+with+sensor&itmmeta=01J7HRG9E7KDCYT0XVE25CVX7Z&hash=item45137c0e36:g:fo4AAOSwcQNkLm3E&itmprp=enc:AQAJAAAA8HoV3kP08IDx+KZ9MfhVJKmwUYluezZHg4j1jZ8imsPl8X7enricGzt7wZ8HqG5oPvXfPc4pyIRMVuInnuO7pgwDNiQUdqhgtRruUTrJWjKjIdrX3sSX11HkuEtpiKZLyzxqPUXwvj3pDKZgba9xTqouEKO3c1NCAkRb9eBbP/J1kTiLPZ/EKULo1+YPWuFnrOWM1briyO8WomQIlp4rm/A3tCS4/jYAxCwxWNuCDIkfSnnZGW1S/GoAvPWeHpS1hGSzX3OKh7/VprJ5ojI6587IBIsAbEgTWGmsMc3jgVHF9fIktb9G9gKkgqeYkaCFuw==|tkp:Bk9SR6yXwbi8ZAInstalled new pan trans filter and flushed the amsoil out after 700 miles. Put new amsoil in with a new cat spin on filter. I also installed a new CAT coolant filter and CAT water/fuel seperator and new fuel filter. The water/fuel seperator was about 1" longer than the wix and the fuel filter was almost 2" longer. The fuel filter is a 2 micron filter. Other photos are just taking Brutus out and stretching his legs. Next upgrade will be adding a turbo and helping drop overall egts.
