M1084 Allison transmission problem
Unimog66
Entrelacs, Canada
Hi
I have a m1084 with an Allison transmission , I’ve already changed the oil . it gives little jerks between the second and third , all the all gears shift smoothly . Any ideas what it could be
thanks
Ronmar
7,624
Port angeles wa
how much weight you got in it? any codes stored(press both arrows to enter diag mode use mode button to step thru the 5 memory locations).
3rd is where lockup is engaged, and with the 2:1 hubs, the trans has a real mechanical advantage so it satisfies lockup requirements almost immediately/in conjunction with the the 2-3 shift. put 2 tons on the back and see how it shifts...
Unimog66
Entrelacs, Canada
Perfect I will put 2 tons in the box and get back to you
thank you
