- 143
- 17
- 18
- knoxville tn
I have a M1061 and am doing general maintenance and clean up. looks like i need to replace several of the hydraulic hard lines to the wheel cylinders. I've read the TM, but only find master cylinder replacement info. i will need to bleed the system. question is, unlike a car master cylinder with a reservoir on top where you can see level, these just have a fill plug. do you just fill it to the top, bleed and keep it full to the top of the fill plug?? the way they are vented at the fill plug seems to indicate that's how they work and just leak out excess if over filled?? and is there another manual that covers the brake system actual repairs? master brake cylinder? i have TM 9-2336-376-14&P. Thanks
