What have I done... Oshkosh P-19
Baloo
49
Clarksville, TN
The pictures will come soon, sorting out tires and what not now. Tennessee is the best! SF97 to motorhome title in 20 minutes! Need to find some similar offset 20" wheels so I can use more common tires. The bolt pattern measures out to the same as a 5 ton.
Sent from my SM-F946U using Tapatalk
canadacountry
480
Canada
bit offtopic but if any of you are currently wanting another example of dual-power vehicles then try these https://i.ytimg.com/vi/lktS7t7vEMU/maxresdefault.jpg (could be a simple 4-inline engine for the tires but a big v8 for the blower part at times! heh. oh and some of these vehicles are simply based on a normal short 2-axle hood truck with the chassis jacked up a bit as to run a new driveshaft underneath all between the rear-mounted engine and front blower)
