MEP 803 A tripping CB1
jaybird67k
25
Texas
So after all the work I have done to this generator and I have it all buttoned up and ready for use the CB3 keeps tripping. It never did this before through the entire process. It's not a big deal because I reset it and it works fine I just want to know why.
Any help is greatly appreciated.
Thanks, Jason
Jeepadict
706
Round Mountain, NV
First step of troubleshooting: duplicate the discrepancy. Since you have that done, don't reset that CB more than once for things like to melt and catch fire if you do. There's some fault logic troubleshooting guides in the TM that may prove useful.
jaybird67k
25
Texas
The GFCI in one of my sets is flakey. It doesn't trip, but much of the time after starting I need to "flick" the reset button to get power to the outlet.
Does yours trip and pop out?
I don't know. I run it and shut it down then next time i go to start its tripped and I reset and starts normally.
kloppk
3,526
Pepperell, Massachusetts
I'd suggest disconnecting the GFCIs output to the outlet and see if the tripping stops. If it does the outlet may be bad. If it still trips then I'd say the GFCI is toast.
jaybird67k
25
Texas
So checking out CB1 I have a open connection across V5 varistor.
Any suggestions? Can I put a resistor there if not does someone know the value of V5 so I can order one?
Thanks
jaybird67k
25
Texas
Well, you could look in the Schematic or look the part number up. But Kurt has posted it several times in the forum.
Part #: V68MA3B
Thanks my friend. The Veristor looks good and is red in color so I guess it just gave up the ghost.
My luck I'll replace it and CB1 will keep popping 😂
jaybird67k
25
Texas
Yes I have downloaded them. I think I have some duplicates so I attached a picture.
I just never know which one to look at.
Also I just read that a Varistor will check open with no current running through it so I guess I'm back at square one with CB1 popping when I hit start. I have checked all the wires from it for continuity and they checked good accept across the Varistor at the bottom that checked open.
Thanks so much for the help.
jaybird67k
25
Texas
Or maybe CB1 is just bad?
Can I just tie them four wires together off the two terminals and see if it starts?
Hopefully I can buy CB1 if its bad.
Guyfang
24,058
Burgkunstadt, Germany
This is a really bad idea. Unless you want to burn something up.
Guyfang
24,058
It tripps when I hit start position.
It started 3 times this morning no problem and didnt trip but I have had it trip on shutdown.
You think it's weak?
This is the first time you have written this. We need ALL the facts.
jaybird67k
25
Texas
Thanks for the warning on tying the wires together. When I first got the unit and did the necessary wiring because of a mouse house it was tripped when I went to start it. Reset CB1 and started it probably 20-30 times with no problem. Now it just seems flakey. I started it this morning with no problems then later when I tried fuel pumps come on relay engages but as soon as I hit start the last position it trips CB1.
Yes I can have someone video me starting it.
