jaybird67k
- 25
- 28
- Texas
It wont let me attach a video
Post a video to any of the supported sites (look at the three dots and down arrow on the compose/reply header bar, and then click on "media" that then lists which sites are supported. Put a video there and link using the media button).This is the error I get
There is no amperage. It's either open or closed. I don't know what you mean by "supported sites" It doesn't support mp4.Post a video to any of the supported sites (look at the three dots and down arrow on the compose/reply header bar, and then click on "media" that then lists which sites are supported. Put a video there and link using the media button).
Have you considered measuring the current through CB1 with a high quality DVM that can record maximum amperage?
All the best,
2Pbfeet
Yes, the CB is either open or closed, but in going from closed to open, how much current is it drawing? I.e. does it work, or is it leaking out at a low current?There is no amperage. It's either open or closed. I don't know what you mean by "supported sites" It doesn't support mp4.
All the best,
2Pbfeet
To post video, reread the instructions above; I am sorry that it wasn't clear.
All the best,
2Pbfeet
All the best,
2Pbfeet
Your videos worked.I didnt see a attach media button so I posted a link to my YouTube. I dont know if that will work.
Thanks I'll try that and let ya know.Your videos worked.
Interesting, CB1 pops when you move S1 from Prime/Run to Start.
As previously posted you ought to measure the DC current going through CB1 to know for sure if the CB is bad or if something is drawing too much current.
That would be the right way to start to track down the issue.
A quick test that might shed some light is.... unplug the 2 pin plug supplying power to the primary fuel pump. This will reduce the current load through CB1.
Then see if CB1 stops popping when you move S1 from Prime/Run to Start. Just see if the starter engages or if the CB1 pops.
