MEP 803a Auxiliary Fuel Connection
Superfrank
Daytona Beach, FL
Hello Everyone,
New to the site and so much info on here. I bought a MEP 803a Generator. Very low hours completely gone through. Very happy with it and I'm trying to set up the auxiliary tank. I need to know a couple of things
1) what the fitting size on the generator itself?
2) What size fuel line should I run?
I plan on going from a 210 gallon aluminum tank, (guy built the wrong side for a yacht so I got a good deal), through a marine diesel fuel filter water separator and finally into the generator. I live in the country and we've lost power out here in the last 2 hurricanes once of 5 days and the second time for 9 days. Never again, I hope! It's set up with an SE rated auto switch and remote start board. Works like a champ! Runs the whole house no problem. AC, Water heater, lights, fans, stove/oven, TV & Internet. I just can't cook a turkey in the oven and dry clothes at the same time. Truly a rock solid unit! The fuel tank is also my filling station for my tractors.
Thanks for your help.
Frank
Digger556
608
Denver CO
Welcome to the site! And congrats on your purchase. It looks like you are getting it setup well.
Like Uniquify stated, the fitting is AN-5, which can be harder to source. Most race shops jump from -4 to -6. I just bought a bunch of -5 JIC fittings from www.discounthydraulichose.com/
Also +1 vote for 5/16" line unless you are running a long distance, then I would step up to 3/8".
Light in the Dark
5,889
MA
Welcome to SS. As others have said, its an AN-5 (or 5/16 JIC in the aftermarket world). What fitting is on the tank, first and foremost? They make auxiliary fuel lines for these sets, so maybe you should use one of those, and just hook it up as needed (install an in-line valive to shut off fuel flow, so you can discontinue fuel line as needed)?
Superfrank
Daytona Beach, FL
Thanks for the information guys. The tank has a 1/2" pipe thread hole so I can use pretty much whatever size fuel line I want I'll just need to get the appropriate fitting. I wanted to size the fuel line properly for the Aux. pump so I wasn't sure what to use. It's a short run probably 4' by the time I come out if the tank, to the filter and then back to the generator. I have some 1/4" stainless braided fuel line in the shop I was going to use if I could, is it too small? Should I go 3/8" or 5/16"? Thanks for the link to the hydraulic shop, and you're right I had a heck of a time finding AN-5 it was always AN-4 then up to AN-6.
Thanks again much appreciated!
mijoe
Tallahassee, FL
Hi All,
Has anyone modified a typical diesel fuel can to have a connector on the top that can be connected to the aux fuel inlet? On my personal 803, I have a jerry can and a barrel adapter that I use, but the actual jerry cans and barrel adapters are costly and not common in the US (official jerry cans are not EPA CARB compliant). I have been thinking about piecing together an adapter set like in the posts above, and then modifying a few fuel cans so that my elderly parents can use it with their 803. The thought was that they could have 9 gallons internal and 5 external, just moving a hose from one can to the next as needed. Has anyone already tried anything like this?
2Pbfeet
758
Mt. Hamilton, CA
Hi All,
If you are running NATO (Wavian type) style Jerry cans, these folks have one;
Or it may give you ideas on how to make your own...
All the best,
2Pbfeet
Light in the Dark
5,889
MA
This user can square you away with the whole package:
Light in the Dark
5,889
MA
Well if you tie to a Jerry can, it'll probably empty it into the machine before that is a concern (with a 9 gallon tank on an 803, you might actually empty the tank before the high level pump shutoff is hit.. Which will make the pump run on and on and on).
m32825
170
Central Florida
55 gallon drum with siphoning issues. Currently break suction at the bung fitting, but a valve would be more convenient. Thought I would check for a go to solution before reinventing the wheel (first time for everything).
2Pbfeet
758
Mt. Hamilton, CA
Bung vents?
There are also smaller versions that do bidirectional venting, but not all of those have flash back screens or mechanisms.
All the best,
2Pbfeet
Toolslinger
119
33
PA
If you're just trying to stop the siphon, without loosing it, a ball valve with the correct JIC adapters in line with the hose. If you want to let the siphon go completely, then a JIC Tee of correct genders, and a valve on the tap that you can open to let the air in.
You could automate it with a solenoid that closed when the transfer pump runs, but that's getting more complicated than you probably want.
