- 306
- 841
- 93
- Utah, Murray, United States
Hello all, My M813 is a bit odd, with the clutch. When attempting to slip the clutch to ease my rig into gear the clutch with grab then release then grab harder and release.
Example: Trying to back up very cautiously along the side of my house which is uphill slightly, as I let out the clutch, with the intention to slip the clutch, it will engage and then release then come back harder and almost fully lock in and jerk my rig backwards when it was unintended.
I have thought that maybe the flex between the motor/transmission and t-case inside the frame rails may be just enough that the play is sufficient to allow for movement to physically shift in the frame and shift the clutch mechanical linkage between the cab mounted pedal and the motor/trans/t-case.
I haven't closely inspected the mounts for this but I am guessing they are OK. If so and the flex is just getting in the way the only way I see fixing this is to replace the manual linkage with a hydraulic master/slave setup.
Anyone else experiencing this issue?
