Duramax vs Cummins HMMWV Conversions
4x4nutz
117
Mico, Texas
Two things.
This is a dead thread from 2018. Holy ICE Batman. Detroit Diesel internal combustion engine swaps are hard.
This thread needs to be moved to mods and conversions.
So what is hard about it and how many have you done?
Mogman
9,583
Papalote, TX
This is when I was finishing up the swap. Got @40k miles on it since then, No regrets
Do you have any more photos of the conversion? if so please post!!
Also what trans and transfer case did you use? Was that a mechanical Cummins or common rail?
goobie
Hiram /Georgia
I made an album on Facebook BUT I have since been evicted from Facebook. I will start with uploading pictures
What are the pros and cons of each engine? I'm specifically talking about the predator conversions that they offer.
Lets hear some arguments for each side!
duramax is the easier of the two swaps. I went the cummins route because i have seen a lot more cummins engines with 800k+ miles than a duramax. i have been making a living as a mechanic for over 35 years, I have owned my mechanic shop for 21 years. I always prefer to work on a cummins than a duramax just from a simplicity standpoint.
Mogman
9,583
Papalote, TX
What makes it more difficult than a Dmax conversion, is that an Allison trans?
Mogman
9,583
Papalote, TX
2006 the civilian H1 Alpha came with a duramax , So the mounts and brackets are available. All the Cummins mounts are custom made. That is one reason it is more difficult.
Yes 6 speed allison
I was not aware anything was available, I believe all those parts have been sold, there also would be no cross member because the Alpha used the 4L80 trans.
There is however some adapter plates to adapt the Dmax to the original motor mounts but some other mods need to be made as the engine sits higher on those adapters, they come from some guys that are sticking Dmax motors in old chevy Impalas :LOL:
What transfer case is that? that is an interesting looking adapter.
Also how are you controlling the Allison, that is a mechanical 6BT yes?
goobie
Hiram /Georgia
The 2006 H1 alpha had a 5 speed allison. The transfer case is an modified humvee 242 , it has a clocking ring to get the angle right for front driveshaft. The alison TCM is in one of the pictures, it is mounted in the battery box under the seat. 6BT with mechanical P pump.
Mogman
9,583
Papalote, TX
So the TCM does not require any information from a ECM? was it originally driven by a mechanical engine?
I was led to believe the GM TCM needed the ECM to work, I have communication between the ECM/TCM and the TCCM, I love the shift on the fly transfer case and am dang glad I did not install the mechanical transfer case I had bought because I thought it would be easier and no doubt it would have :)
What gear ratio diffs do you have?
VERY nice build
goobie
Hiram /Georgia
VERY nice build
The 242 is a mechanical transfer case. Alison TCM does Not need much to be "stand alone" . I'll include more details and were i got stuff from in the new thread
deadlydayne
Texas
What electric fan/shroud combo did you use?
I have an ECV so my rad is a little bigger, but I've been lookin for an electric fan setup for it for some time and everyone recommends the Lincoln Mark VIII/ Ford Taurus.
Also in regards to the electrical, did you convert the whole V to 12 volt or did you keep it 24 volt?
