Yes, I have read through past threads regarding charging options-
Need to keep my 24v system charged as ever o e does but need some help.
1. prefer not to use a 24 V charger as I’m reading it may not balance the batteries correctly. Is this a valid concern?
2. I don’t want to have to disconnect the terminals to charge the batteries separately with a 12v charger because it’s a pain and I want to keep the connections tight. Can you use a dual bank 12v charger WITHOUT having to disconnect the cable between the two batteries?
3. Using Optima yellow top batteries-AGM
4. I see a lot of people installing chargers under the seat in the battery compartment. I have always charged where the batteries can vent and never put the charger right next to the batteries due to gasses. Is it save to charge with the charger in the same compartment, unvented?
Hope this make sense. Looking to find a reliable and safe method to trickle chat while in storage.
Thank you
Thank you
