- 18
- 14
- 3
- Olympia, WA
Posted on Facebook and the comments I got were "normal", "possible injection pump", "run 2 stroke oil in fuel", and "use ATF in the fuel". Wondering what steel soldiers think.
A while back I made a post about a smoking exhaust. I ended up doing all the glow plugs, all injectors, and fuel filter. Thing runs like champ! Except 1 thing. I have some kind of piston slap or something and it's loud and annoying until it warms up, where it is still there but hardly noticeable. I had this issue beforehand but assumed it was a clogged injector or something.
All original glow plugs and injectors were intact (it was a reman engine so paint was chipping off as I took plugs out). I have not done a compression test yet.(money is tight sry) Only smoke is on cold start (little puff). There is absolutely zero blow-by. No oil burning, No misfires, and no effect to performance.
Oil pressure is 60psi cold and 20ish warm
Just wondering if anyone has seen this before. Because I cannot find this same sound/issue on the interwebs.
Video 1 is coldish idle and video 2 is 220f idle
https://youtube.com/shorts/FHXKLt2Ie8Y?feature=share, https://youtube.com/shorts/31vn3lia6-0?feature=share
Edit 1: I've ran 2 tanks with Diesel Kleen. Also, The noise is almost gone with any throttle input.
