Just beginning my mep-003a journey
Rodburner
44
13
NW Oklahoma
I disconnected the jumper and connected both wires going to the oil pressure switch together. Generator fired up quickly. Thanks all for getting me this far along. Will any oil pressure switch work or should I use a specific one. Green Mountain shows one for $77.00 but I thought that was a little high. Let me know. Also I let the generator run for several minutes so not to be starting and stopping, noticed before I shut it down the voltage had dropped to zero. Planning to get the Kill-o-watt device to check frequency but haven’t had anything connected to it except for a led light while testing it. Your thoughts? Thanks again, need to put it up for tonight.
Guyfang
23,912
Burgkunstadt, Germany
Figure 49, Item #15,
NSN's
5930-01-039-3140
5930-01-195-5537
5930-01-229-2707
Part numbers:
309-0641-02
3090177
76052-14
C030917700
M-4008-14
M1423-14
SM-2A-14K
Red numbers are prime. The red part number is Cummins. I would try that number first.
Origanal cost was $21.00
Rodburner
44
13
NW Oklahoma
I’ll see about getting the pressure switch coming my way. Does anyone have information about operating the generator without any load? I think the person I purchased it from said it could cause damage. Wanted your input before I kept testing without a load.
Scoobyshep
1,440
Florida
It won't get as hot and can lead to wet stacking but that's an easy fix
What you shouldn't do is run the engine at idle (or really low speeds). This can make the avr strain
Ray70
5,849
West greenwich/RI
Definitely don't idle or operate under 56 Hz or so.... without disconnecting the excite wires, you WILL very likely damage the VR transistors if it's run at low RPM too long.
Don't worry about operating without a load, the prior owner was probably thinking more about the older single cylinder Vietnam era. gasoline generators which rumor had it, required a light bulb or other small load to be on all the time, but that may have been a myth.
Chainbreaker
1,962
Oregon
Couple of things...
1. Beware! The AC reconnection box is a mouse attractant!. For whatever reason, they seem to find the opening where the Terminal Lugs are & crawl into the box there. Then they have a field day making a nest & chewing wires. Mouse pee is very corrosive & with all that "mouse renovation" inside the box internals it will destroy & short out components the next time you go to start it. A quick fix is to stuff a piece of the black foam pipe wrap in the ~1" opening flap to close off access. The more permanent fix is to use some 1/8th" hardware cloth in the back past the load terminals to close off the opening so they can't drop down inside the box. Here is a link to what I did: (4) MEP-002a only outputting 125v | SteelSoldiers
2. Whenever it gets to be really cold weather (below freezing snow & ice type weather) it can help benefit better combustion to slide Air Cleaner flap lever to Winter mode configuration. The intake air gets the benefit of pre-heating once engine is warmed up & is less likely to wetstack during no/low AC loading.
Guyfang
23,912
Thanks, I’ll roll them up a little more. Just didn’t want to fill mufflers with rain.
can not happen, well maybe in a hurricane. Normally they point straight away from the set. Was a big problem in the 70-80's. The exhaust fried thousands of Batteries. ( @peapvp ) Bet you cant find that PS article!!
peapvp
1,217
Basehor, KS
@Guyfang that would be correct.
For the interested reader, these are all PS Articles from 2019 to present, which includes some 531, 1050/51 and other newer model info / issues
PS Magazine including gensets
