- 2,135
- 3,501
- Pepperell, Massachusetts
... I remember Guyfang saying hesleptpassed out on top of one of them...
Or when it runs away like a member recently had happen.For those of you who want to sleep on top of your Genset to make sure it is running, put one off those right next to your Genset, this way you won’t have to go far when nature calls…..
Probably too late at that point.... time for a change of underwear!Or when it runs away like a member recently had happen.
I’ll jump in here. I have Kurt’s controller with the Generac ATS control card. The additional controller enabled me to buy the much more affordable Generac ATS rather than the quite pricey 2 wire ATS on the market.No iam not. I just wanted to make sure what I need. I thought I wouldn't need the extra ATS control card. Do you have a mep? How's your setup?
When hurricanes or tropical storms come our way I switch over to genset power before the power goes out. Beats going out in the middle of a storm!usually when the power is out it’s because of the weather, so it’s pretty nice not having to go outside
I went this direction so that if I’m not home my wife and 2 babies will have power. Also, usually when the power is out it’s because of the weather, so it’s pretty nice not having to go outside
let me know if you have questions. Also, feel free to PM me and we can even jump on a call
An interlock is definitely the cheaper option.Can you send me a picture of your setup? Debating if to go with an ATS or interlock
It appears in the generator picture that the OP gauge is reading quite low. If you have 45 PSI (I assume using a mechanical gauge) then I suspect an issue with the OP sensor, wiring or gauge. Correcting that issue will make my Remote Start then know the generator is running. If you need help with this feel free to contact me. - Kurt... I say this because currently my generator is reporting low oil pressure despite have 45psi. The controller monitors OP to determine if the engine is running, so my controller thinks the machine has stalled.
I really came across Mep after looking at the generac propane/natural gas generators. It was looking at propane consumption that made we want to look into diesel (coupled with better shelf life). SO basically what i wanted in my system was self sourcing ability of diesel, ease of operation of a generac, quiet 1800rpm.. and you can see how it led me to MEP's. My point is though that I came to MEP's wanting automated operation. THAT is the benefit to the ATS.
As far as compromises with an ATS, the only thing I can think of is the cost. You can get an interlock kit installed quite cheaply. I paid my neighbor $500 for the ATS install (he is a master electrician, but I handled connecting the control wires to kurts controller), 800 for the ATS, and i think aroung 8-900 for Kurts controller.
If for whatever reason you have an issue with the controller, you can operate the generator and the ATS manually still. I say this because currently my generator is reporting low oil pressure despite have 45psi. The controller monitors OP to determine if the engine is running, so my controller thinks the machine has stalled. This means that if we lose power I have to start my machine like every other sucker until I figure out whats going on with my generator.
Anyways.... heres some photos. Please note that while the generator is in its final location here I have since removed the sheathing and have it blocked up! it was just on the board so i could move it with a pallet jack. Also some of these pictures were taken mid install.View attachment 935507View attachment 935508View attachment 935509View attachment 935510
Kurt, thanks for the offer! However you and I have been emailing for some time now! Name is Tyler and I’m working on Genpal too.It appears in the generator picture that the OP gauge is reading quite low. If you have 45 PSI (I assume using a mechanical gauge) then I suspect an issue with the OP sensor, wiring or gauge. Correcting that issue will make my Remote Start then know the generator is running. If you need help with this feel free to contact me. - Kurt
Just checking if you still needed help.Kurt, thanks for the offer! However you and I have been emailing for some time now! Name is Tyler and I’m working on Genpal too.
Obviously I went with ATS and personally feel like its better for my situation. I love automation and systems that just work when you need them. keep us updated on your install. I always love seeing what people come up with!Thank you so much for replying. Big help. Seems like I might just go with an interlock and Kurt's remote controller so I can start it up with my phone and also like that I can see more info. Thank you and nice install
I appreciate that! The truth is my generator problems aren't the responsibility of the control card or its maker. that being said ill follow up with an email to you and tell you my findings when I get home this evening.Just checking if you still needed help.
