- 324
- 239
- 43
- Myakka City, FL
I am presently frustrated by not having knowledge of Allison MD3070PT Transmissions like I would like so that leaves me with turning to y'all for my information but I think this might be profitable for now and time to come. I did not find the information on a search so maybe my wording was not correct. If in fact I am in error and there is information on this subject please direct me. Thank you.
I have two transmissions, in one, the clutches are gone because of water and the back case got shattered and I have another transmission in what appears to be good shape from a unit that was rolled. The oil was very clean and it was working when it came to an early demise. Now I called Weller transmission with the serial numbers and it was stated the they were the same in mechanical parts BUT the valve bodies were different. One valve body was an 81 series and one was the 82 series. I probed for what that meant to me and though the fellow could give me some indications what it meant, he could not get specific.
It may have to do with different engines, or speeds, but it doesn't seem to matter as far as the mechanical end is concerned..So I am told but don't know. Yes I am looking for clarification. Can the Mechanical end with good clutches be used by "merely" swapping valve bodies? Do I need to abort the whole issue? Is the wire harness still the same with plug? Just change the Key Pad?
That's right - HELP!!!
I am almost sure these questions been asked before and someone has the answers and they most likely will be asked again!!
Thank you, Lugnuts
Thank you, Lugnuts
