Lifter cover gaskets....questions
EastRidge
Plymouth Wisconsin
Just received my lifter cover gaskets for replacement of my very tired current installation.
Fel-Pro from Vintage Power Wagons.
Looking at the work ahead......are there any shared tips going into this.
It's not a very technical installation BUT is it worth the trouble to remove the fuel pump or the hard line at the rear of the block.......or can a guy just be patient and nimble and get it done without......
Thanks in advance.
Roller
58
North Lake, WI
Thanks in advance.
Patient and nimble will work, although removing the fender makes the job easier.
EastRidge
Plymouth Wisconsin
I forged ahead, as I wasn't pressed for time.....
With just doing it, I found a few tips on my own:
1.) Working from the bottom is fine for 90% of the work.
2.) The PCV valve fitting isn't really an issue for removal, but it is for installation. I removed the brass fitting in the block to allow free fit of the newly gasketed part. This was great until the reinstall......you can't turn the nut with a new gasket. SO,....carefully remove the lifter cover, REINSTALL the brass fitting INDEXING IT with a flat side to the cover to allow clearance. Carefully reinstall part with just a 1/32" of clearance. An inch is as good as a mile.
3.) Behind the fuel pump was fine. Cleaning the silicone off was tedious. The learned trick was to fetch a 5-6" piece of vinyl tubing and shove the thumb screw head into it......as your fingers just don't work.
4.) Snuggled up with a small adjustable wrench or a small combination wrench with something through the "hole end" to enable that......feels right.....torque spec.
Test drive, after the oil change was a "no leaker".
Very happy.
