JasonS
- 167
- 63
- Eastern SD
I am having trouble with the brakes on my M818.
A little history. The truck has been modified to one rear axle and the glad hands removed/ capped off.
I was having trouble with the brakes wherein I had good power brakes but as I sat with my foot on the brake pedal, the pedal would rise and there was no power brake assist; only manual brakes. I attributed this to a faulty air piston seal in the brake booster and replaced the brake booster. I also had, on rare occasion, a situation where the brakes would lock up.
After replacing the brake booster, I had no power brakes with 120psi system pressure. No response at all from the booster. Bleeding air off down to ~100psi allowed the booster to operate. I reset the air governor to 90psi and retested. The amount of brake assist is highly variable and I had one occasion wherein the brakes locked up hard and I had to bleed air off to get it free.
1) Is this issue related to one of the three air shuttle valves?
2) I will not tow a trailer with air brakes nor be towed with a vehicle having air brakes. Can I remove the two frame mounted shuttle valves and simplify the air booster plumbing to something like the deuce: hydraulic in, hydraulic out, air in, vent out the top, pressure out to only the brake switch, and cap off the line at the rear of the booster.
Other suggestions?
Other suggestions?
