JCamp
- 3
- 3
- Massachusetts
I’m using home heating oil #2 to fuel my MEP803 A. I’m adding lubricity additive. I have enough fuel to run the genset day and night, but I’m worried about wet stacking. Is there a rule of thumb around how much load should be on generator to prevent wet stacking? For example, should I run it at minimum 20 or 25% load at night when there isn’t much draw? Or, should I make a point of running it harder by turning on an oven, electric heater, air, conditioner,…
It will be running two standard refrigerators, one below the counter freezer, well pump, and the the usual other things seem pretty low draw.
I’m asking because my mother has medical equipment that should run all night, very low draw but nonetheless it needs to be run consistently. One option is getting a rechargeable battery unit that will supply 120 V to run that equipment, and just turning the generator off at night. However, that wouldn’t run my refrigerators, freezers, and water pump. Any comments or suggestions?
