I have a coolant system question (which I know this board loves!) related to the Thermostatic Coolant Fan Switch's: are there variants?
I have a 2001 M1097R1 with the 6.5 L Engine. On a recent trip the engine overheated and diagnosed it back to the Thermostatic Coolant Fan Switch not engaging the fan.
I went online and bought the following switches off of Midwest Military Equipment not knowing which one I needed. Although the pictures look slightly different both sensors came in the same size/shape.
Replacement Thermostatic Coolant Fan Switch (think this is just a pulled part)
HMMWV Thermostatic Coolant Fan Switch (think this is an OEM re-manufacture)
Here are the issues that I encounter which makes me ask if there are variants:
While not an originalist I am just trying to get the proper Switch to get on the road. Not currently looking for the fan delete kit or trying to run the engine colder than the OEM specs.
Does anyone have any insights? Is there another Thermostatic Coolant Fan Switch I should try?
Thanks in advance!
- I have attached a photo of where the original sensor/switch was pulled from (to confirm it is the correct part)
- Note how the sensor sits relatively flush against the housing
- if memory serves me the fan would kick on at 220-230(?) when working
- I have attached a picture of the sensor pulled out verses what was received
- As seen the thread location and pitch are very different
- When I install the new one, I can maybe get 1-2 threads in before I meet stiff resistance, but it does screw in
- The old sensor goes in, with applicable resistance, and out (indicating cross threading is not an issue)
- In an effort to get back up and running I installed the HMMWV Thermostatic Coolant Fan Switch
- As seen compared to the original sensor the new one protrudes out a significant amount (it is as tightened as much as I am willing to get it)
- The sensor DOES kick on the fan - HOWEVER the fan does not kick on until 240 degrees
- The fan kicking on at 240 degrees is causing overheating issues, especially at slow speeds, which makes me not want to drive it
Thanks in advance!
