Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Ok so tomorrow I'm going to try taking it apart and doing the fuel lines. Any pointers for them? How do I get them all off? And anything I should do in addition? I have the fuel tank nuts but seeing as I just put 3 gallons in I don't want to pull the tank if I don't have to Diesel is expensive! I will figure it out but thought I should ask!
Even if that gets wasted, it's better than a full tank (or more if AUX is being used) being wasted when the existing one leaks the first time you run it overnight & it decides to spew. Then you are out the fuel & power. Changing them out is not fun no matter the route you go, but making sure it is done right, you won't even need to worry about it leaking again.
Better to drain the tank now when you have time and control, than later when you might not. I would suggest that as this generator is new to you, while you are changing the tank nuts, check for debris, slime, and crud in the tank, and wipe the inside clean. No sense in washing crud into your filters or worse.
There are several threads here that cover changing the fuel lines, but in general, they are just fuel lines.
So I got it disassembled it except the fuel lines. They scare me a little. @CallMeColt do I need a heat gun or do I just pull the tubes off and on? The petcock worked great. The bolts to get the muffler off were a PITA though!
Pull, yank, cut. Doesn't matter. They're designed to bond after some head cycles to seal well. It's why those plastic tees are a throw away item in my opinion.
