Anden mcleod (mep-017a)
- 23
- 3
- Jacksonville florida
Believe it or not, the schematic and all the wire labels are fully legibleThat is the correct NSN.
Sounds good, enjoy your sleep.Its 00:00 here, so I may drop out soon. Old people need their sleep.
Still on the computer at midnight, shortly after tripling your normal nightly beer consumption! You're still doing better than some of us (slightly) younger folks..... 2 Sam Cold Snaps and I was asleep by 23:00 Friday.
I don’t really want diesel. I prefer gasoline.I'd toss that thing aside in a heartbeat and get an 002, if you want 3 phase, simplicity and affordable and an 1800rpm diesel.
how much 3 phase output do you need might be the better question in order to get you the right generator or keep working on this one.the issue is either i have to fix it, or it has to go either to a scrapyard, or sold as is, space is a limitation, the main reason why im even bothering with it, is the fact that the engine only has 30 hours, and i need 3 phase.
Not very much. I work on commercial ice cream machines and ice machines, and many units use 10-15 amps 3ph. Some even lower, but the reason I purchased this one is it was cheap. I’m not looking to spend any more then 1000 or so on one.how much 3 phase output do you need might be the better question in order to get you the right generator or keep working on this one.
For what you need it for, I would second the phase converter suggestion, but not a rotary phase converter, a VFD, which for 15A will weigh about 7lbs and be 12"x6x"x6". E.g.At home, not interested in any phase converters, as I plan on moving soon. My requirements are under 600lbs, under 1000 dollars, and preferably gasoline, but would make diesel work. I’d really want to fix this one as it’s already in my yard, and I already have money invested.
