My new hobby: Wood military vehicles
goldneagle
1,203
Slidell, LA
goldneagle
1,203
Slidell, LA
Got the drawers and door completed on the lathe stand
goldneagle
1,203
Slidell, LA
Took 11 LONG segments to make the hull of the DUKW.
goldneagle
1,203
Slidell, LA
After reviewing a lot of pictures of actual DUKW vehicles I decided to make some modifications to my model since the plans are not accurate. I was able to curve the 2 front corners. I also beveled the engine cover. Steering in on left side now instead of centered. Now has 2 seats instead of 1 in center. Front windshield in now split into 2 piece. The model will not be perfect but will be closer to the actual vehicle.
20,466
Good call @goldneagle !
Those upgrades definitely make the DUCKW model a lot more realistic. I wonder if the co-pilot was manning a .50 while they were "headed in" for a landing. According to a quick lookup on the web, about one in four DUKWs came with a .50-caliber Browning heavy machine gun on a ring mount on the right side. There is also a hand mounted search light on the drivers side of the cockpit. There is a small propeller under the back bottom if you have a way to create one...
