Dark Seas M1008 Project
DarkSeas
314
Leland, N.C.
See if you turn it off all the way to see if it'll lock the steering wheel. It should lock. If not changing the cylinder takes 2 pullers. One for the wheel and one for the spring lock under the horn. Not hard and not expensive.
So I can get the steering wheel to lock, but I can turn the ignition cylinder with no key in it and the wheel unlocks with it. Super weird. I have seen a video of someone taking off the wheel and getting to the cylinder to replace it. I might look it up in the next month or two, the cylinder is like $35 but the pullers and stuff will add onto that bill.
WWRD99
1,830
York Pa
Ok so sounds like the cylinder is worn out. I know you can rent the puller tool from advance auto but I'm not sure about the press for the c clip...some have that in it. Those are cheap to get though. Things I like to replace while in there are the parts for the horn...all of them! The insulator likes to fall apart and little springs like to fly.
DarkSeas
314
Leland, N.C.
Been a while since an update. Have been working on my 2013 GMC 1500 (my daily) replacing the entire front suspension over a weekend. Finally got the money for the parts together and then the weather right over a weekend to get that done. Jack stands in a parking lot apartment - I had a lot of spectators giving me unsolicited advice but never offering to put their hands on a wrench with me. Figures, right? She's fixed and aligned now and still rides like crap, which is awesome.
I've tinkered a little with the CUCV while I wait out the wedding (early Oct) -- have not messed with the lock cylinder yet but I have gone and adjusted the IP timing a bit to get it to stop smoking at idle by about 95%, to the point where it isn't noticeable at all anymore. Crazy thing is, I've got it WAY farther to the driverside to get it happy than it should have ever needed, but the more I inched it back a line width at a time, the harder it was to start/jerkier it was idling/and more it smoked. Maybe it slipped timing or someone messed with the timing cover and didn't time it right putting it back together? Who knows.
I also went with an IR temp gun and checked all my exhaust ports on the exhaust manifold on a cold start to see if I had any cylinders really struggling to keep up with the rest, didn't really notice anything there. All cylinder exhaust ports seemed to be within 5F of each other, I'd say that's fine. Was looking for like a 15-25F difference from the rest to see if I really did have a compression issue.
Let's see... exterminated some fire ants that decided to move in when the field behind the truck flooded during the hurricane. Also diagnosed that I've got a bad dimmer switch and that looks like a really cheap fix that can improve my QOL with the truck - saw a new switch for $13. Not bad.
Looking at my new valve cover gaskets leaking oil, and all the oil leaks the motor seems to be struggling with, I thought about the fact that I know the intake is sucking oil vapor up through the CDR valve and burning it, likely that last 5% of smoke I see at idle. Might be an easy fix to replace the CDR with an oil catch can that drains back into the pan somehow. At least that way it's not BURNING oil anymore, it's just leaking it.
Also started thinking about tinkering with the steering gearbox that's got a leak, or the rotting out inner fenders I could replace for $40 each and put stock battery trays back in... but I have to keep telling myself...
"No Jack, don't take apart something else. Laney wants this truck at the wedding in a month and you always get yourself in over your head on these projects. Also you're broke from wedding expenses"
Soon, soon. Hope everyone's doing well.
DarkSeas
314
Leland, N.C.
Check the ID plate on your injection pump. You might have a HMMWV IP on there. That's what's on my M1009 and I had to turn the timing way up to stop it smoking.
That's interesting. What would typically indicate that on the plate? I can probably look at that tomorrow after work
CARC686
589
Las Cruces, New Mexico
As far as I know, DB2829-4267 is OEM for all 6.2L NA CUCVs. DB2829-4879 is what's available brand new off the shelf. They'll tell you it's good for the CUCV, but I've spent the past year screwing around with fuel and timing and airflow to get it to quit belching unburnt diesel out the tailpipes. It's pretty good now, but not worth the hassle IMO.
adf5565
688
Tioga, PA
During replacement of timing chains on these motors I've also seen the worn chain causing the cam (and thus the IP) to be off by a few degrees from the crankshaft compared to the new chain. Which would make it so you have the IP turned more than expected. The main thing is it runs well so that's more important than where the line is.
DarkSeas
314
Leland, N.C.
Howdy all! Happy holiday season - just wanted to toss it out there see if anybody had some ideas. The wife and I are gonna move back to Maryland in the spring of 2026 (about 470 miles up from where we are at now in NC). I've been looking around at ways I could get the CUCV home - uhaul seems out of the picture, I don't own a trailer myself. Seems like most people are recommending flat towing it. There might be some oddball chance I can find a rental company that rents out tandem axle trailers that are rated higher than the CUCV curb weight.
I've got a 2013 GMC 1500 with a 5.3L V8, maybe my wife's dad will pull it with his 2016 6.7L F350 (I hope... he just spent all this money on heavier duty springs in the back for towing stuff).
I've never flat towed anything before, but looking through old threads from '05-'08 it looks like folks are saying the CUCV shackle brackets in the front would work, but there's something about a "one inch adapter" people are saying they need. I'm looking at "medium military towbars" on google right now trying to figure out exactly what I would need to pull this off.
I know the spring of 2026 is very far away, but I'd like to have my ducks in a row with the CUCV before moving. It's not staying in NC, I will drive that sucker 470 miles home if I have to.
20,362
A medium tow bar should work - and I would suggest that you buy one that already has "feet" on it. Don't forget that you need a pair of chains too. Those run from the back of the tow vehicle to the front of the towed vehicle - Just In Case.
The F350 should pull it with no trouble. On a trip that long, you might should remove the drive shaft and plug the transmission.
DarkSeas
314
Leland, N.C.
If I'm understanding the feet/adapter part right...
Take the D-rings off the front of the CUCV, insert the "feet adapters" with their pin (should be a 1" pin). The feet look something like below:
Then attach the tow bar to the feet with their own pin.
and I'm going to assume that round eyelet end is not supposed to ride on a ball hitch, it's got some other hitch adapter to connect it to the towing vehicle.
DarkSeas
314
Leland, N.C.
Answered my own question - a pintle hitch attachment is what I'm gonna need to pull something like that. No problem.
And yep I am gonna try and see if her dad wouldn't mind pulling it with his truck for me, should be a breeze for his F350 and a hard trip for my GMC haha. He tows a camper a lot with his truck.
DarkSeas
314
Leland, N.C.
Hello everyone,
I finally got my 2013 truck in a better spot, I guess it was inevitable for the old CUCV to start having issues haha.
Since the weather's been nice and warm here, I have been running the truck for 30-40 minutes here and there to let the batteries charge, taking it to the gas station to top off with fresh fuel, cruising around smaller side streets just letting it stretch its legs a little. Couple days ago I had it idling I was listening to music and talking to a friend at the tailgate - it caught my eye - fluid under the passenger side up around the front of the truck. It was dripping fast too.
Cut the truck off and got a smell of the fluid - it's diesel. It was dark out at this point, I did a quick look under the hood and thought it might be the fuel filter leaking or maybe a fuel line or injector. I didn't bother with really getting under the hood and diagnosing until yesterday when I had some daylight after work.
Looks like either my rear passenger side injector is leaking, the injector line is leaking, or the return line/tube is leaking.
1) From my understanding, fuel returns from the injectors by passing injector to injector all the way from one end of the motor around to the other, then it returns to the tank? And somewhere in that flow the IP return connects too?
2) From what I remember putting those injector return lines on a while ago, one rear side of the motor (I think driver side) had just a solid rubber cap with a clamp, and the other end is what actually connected to the fuel tank return line. Makes me think either the injector on the back passenger side either has a loose clamp (those return hoses were kind of a pain to get on), maybe the return lines need to be changed out because they're starting to swell shut, or I might have a plug in the return line to the tank (which I feel like wouldn't be super likely, wouldn't it have clogged up an injectors return line ports before the main return line to the tank?)
Anybody else have an idea of where to start?
87cr250r
2,025
Rodeo, Ca
The aftermarket return lines are the incorrect hose material for the application. They don't tolerate the temperature and you'll get cracks in the ends of the tube. You need to use Viton tubing. If you use Viton tubing you don't actually need the clamps. The OEM lines were Viton.
DarkSeas
314
Leland, N.C.
Awesome thanks so much I'll get some ordered and put on.
