Heavy white smoke cold start
Pstyckiewicz
164
Massachusetts
So lately the temperature has been dropping into the 20’s at night and 40’s during the day. So the truck sits a few days typically before I start it.
On start up it fires right up but blows white smoke that smells like diesel. When I say it smokes it fills my front yard with smoke. It runs a little rough when you apply some throttle but I would say within a quarter mile of driving it dosnt smoke anymore and runs good.
If I drive it then let it sit for a few hours and cool down it fires right up with no smoke. I think it’s temperature related because it has never done this until it started to get cold. I have read that it could be something with the injector pump supplying more fuel when it’s cold?
In addition I replaced the glow plugs and TSU probably and 1,500 miles ago, and everything with the glow plug circuit appears to be working correctly (no flashing wait light).
Any help would be greatly appreciated!
Barrman
1,947
Giddings, Texas
Yes, the oily white smoke on cold start up is the indicator of failing glow plugs. Ohm check them all again to make sure they are good.
This video is for 12 volt CUCV glow plugs, but it gives you the idea of how to check them:
Coug
4,528
Olympia/WA
Either failing glow plugs or some of them aren't getting power to them, which is more likely a harness issue than box issue.
Just because they were replaced doesn't mean they are good. I've seen people install brand new parts and they failed the next day. There are also a lot of cheap glow plugs out there that get sold off as the good ones that end up failing quickly
Boomer T
Southern New Jersey
After checking the glow plugs could the issue be Thermostatic switch / cold advance ?
Pstyckiewicz
164
Massachusetts
So I had to unplug the time delay thing because the fan wasn’t kicking on and it over heated. I’m thinking that the time delay thing is bad or the thermo switch.
Pstyckiewicz
164
Massachusetts
Also found a block heater on it so I got a plug. In addition I read somewhere pushing in the peddle while in the run mode does somthing with the cold advance.
Mogman
10,063
Papalote, TX
It is a "failsafe" system, so if you unplug the temp switch (ether wire) the fan should run, if not it is likely the TDM.
The temp switch turns OFF the fan when the contacts are closed.
Mogman
10,063
Papalote, TX
Tested the thermostatic switch. It’s no good. Got one on order. I’m thinking that’s the source of all my white smoke problems.
The thermostatic switch has nothing to do with starting, unless you are talking about the TSU (temperature sending unit) the thermostatic switch controls the fan
Pstyckiewicz
164
Massachusetts
Yeah I got the fan problem. I believe I read somewhere that it has something to do with the cold advance too.? Either way it dosnt work anymore. Haha
Boomer T
Southern New Jersey
Upon further review of what I read. The other sensor thing on the block has to do with the cold advance.
The cold advance is on the back of the right side of the block ( when sitting behind the wheel). Take the doghouse off and you should see it .
While your at it may as well replace the fuel filter if its never been replaced ( Maintenance ).
Some people here add injector clearer to the fuel once a year ... for another thread
Pstyckiewicz
164
Massachusetts
changed out the fuel filter last year and added some injector cleaner. I typically add some stuff to the fuel every so often. In addition I had already replaced the cold advance sensor last year.
Pstyckiewicz
164
Massachusetts
Ok back to my smoke again. Thought I had it figured out but I don’t. Tested the cold advance switch on the back right of the engine. I have continuity through the switch. Also have 24 volts to the switch and all the way to the 569B wire at the top of the injector pump. So I’m getting power there.
What I did notice is that I start the truck when cold. Let it run for 30 seconds then shut it off. wait another 30 seconds and start it again the there is a lot less smoke. But prior to shutting it off I’m getting a ton of smoke.
Not sure if something is getting stuck and dumping a bunch of fuel or if I’m just looking for an excuse to not change my glow plugs. Plugs have like 1,000 miles on them.
I had checked a few plugs but I’m having a hard time getting an accurate reading.
Any ideas or other test?!!!
Pstyckiewicz
164
Massachusetts
Started truck and took the 569B wire of the injection pump and then reconnected it. I could hear the difference when doing that.
I tested the driver side plugs today and they all registered between 1.2-2.5.
I also plugged the block heater in for an hour then started it……no smoke. So glow plugs?
Can 1 bad plug cause a bunch of smoke? I have to test the other side still.
Coug
4,528
Olympia/WA
Have you tested voltage at the glow plug connectors to see if they are actually receiving power? I read through quickly and didn't see if you had verified voltage at the plugs yet.
Honestly, my truck has maybe 3 or 4 working glow plugs and does massive amounts of smoke. Sounds a little rough until all the cylinders have warmed up a little bit.
As it is worse with the first start and less smoke afterwards, I'd say definitely something in the glow plug system.
