My new hobby: Wood military vehicles
goldneagle
1,111
Slidell, LA
Good call @goldneagle !
Those upgrades definitely make the DUCKW model a lot more realistic. I wonder if the co-pilot was manning a .50 while they were "headed in" for a landing. According to a quick lookup on the web, about one in four DUKWs came with a .50-caliber Browning heavy machine gun on a ring mount on the right side. There is also a hand mounted search light on the drivers side of the cockpit. There is a small propeller under the back bottom if you have a way to create one...
The plan designer did include a propeller assembly. He has it placed a bit high. I will place it as low as this model allows. I am also redesigning the winch in the back. I will notch out the back wall for the proper winch install. I am making 5 bows for cargo instead of HIS 4. I will build an inner tub for the cage area. Also a suspended floor in the rear winch area.
There is still a lot of detail work to do.
19,986
Made some progress on the body moulding. Had to use the fender flairs because the plan did not recess the wheels properly. Like I mentioned it's not a perfect design. Working with what i got.
Wow. That is a lot of thin long strips of wood. The Bows and the Fenders. Lots of room for errors... You do good work!
goldneagle
1,111
Slidell, LA
Right side moldings installed. Made the shovel and ax for the truck. Also made the tubular item for the right side ( looks like bazooka but not sure).
Still need to make the curved moldings and vertical ones for front and back.
goldneagle
1,111
Slidell, LA
So I painted the DUKW Vallejo US Olive Drab. It came out gray/green in my shop lighting (LED). Pictures show it as gray for some reason! I left the model in the shop to dry better overnight. I will look at it in daylight and see what shade it ends up. Let me know what you think...
UPDATE: I brought the model inside the laundry room and the color is correct.! The LED lights in the shop and the phone camera make it look gray. It is OD thank GOD! Need to work on the wheels, stars, lights and mirrors... I will take some new pictures tomorrow.
***Adjusted the tint of the pictures
