- 84
- 123
- 33
- Wisconsin
I recently purchased a 1982 mep003a for $1200. I took it to its off grid home 3 weeks ago, checked the oil, hooked up 2 batteries and fired it up. Beforehand I read most of the TM’s(important stuff) and searched mep003a on this site and read everything I found. White smoke comes out of the front ex pipe on startup but goes away. I wired it to my shop and ran everything I could including my old Lincoln stick welder on 225 amps. Worked without a hiccup for several startups over 2 weeks. Ran it for 30 hours approximately gradually adding new fuel to dilute the old stuff. On the last start attempt the starter spins but won’t engage flywheel. It was below zero in northern Wisconsin. I suspect the starter cutout? I do have a few questions for you guys
The start knob is missing. Using a vice grips. Is there a replacement? I’m not finding one yet
The faceplate control panel is faded and not readable. Should I just sharpie it up? Can’t find a replacement
I planned on bringing home to give it the love it needs but broke 3 ribs so I left it there until I get back.
is there anything I need to do/check on this beast while changing filters and oil?
should I be concerned about the white smoke from front cylinders on startup?
DB
DB
