- 2,110
- 5,380
- Portland, OR
I was 52D (91D now), but attached to Motorpool so most time was spent on trucks.
62A..... Just went through the Hospice experience with my mom. Hats off to your sir! I can't imagine the things you have seen. Thank you for what you do.
The high pinion appears to just be a different third member so swapping over to it should be no different than swapping the third member "chunk" over to "highway" gears. Just a lot heavier. The high pinion is literally the center differential third member from the 6x6 with the output for the rear axle deleted from the factory and a spool in place of the power divider differential.
The difficulty is going to be finding one. At least for the moment. Eventually they will be common since all the A1P2's use them.
It also (unfortunately) uses a different length driveshaft. Several inches shorter.
