- 17,224
- 25,467
- Burgkunstadt, Germany
The -24 TM?
Looks like mje800G transistors are getting hard to find. Mauser says they are in end of life. Any substitutes known?Fuel pump module. It is the little box on the right lower side of the unit, looking at the fuel tank. Try unplugging it and jumpering pins 1&3. If aux pump turns on, then it’s the transistor inside that burned up.
Technically this part is considered a consumable and non-repairable part. But it is actually very easy to fix. You just need to purchase a mje800G transistor and solder it in.
@peapvp If it is a known issue, why not switch to heatsink tape, or a heatsink clip, or a larger, less loaded component that doesn't require the heat sink, to keep the component in its thermal performance zone? Renewing heat sink material every so often seems like extra work at a minimum, but what do I know?@bosko
this is a typical failure due to overheating because the heatsink paste has dried out and the heat is no longer transferred properly from the device to the attached heatsink.
Any electrical apparatus operated in high ambient temperatures will suffer this fate at one point or another.
The remedy is to check the heatsink paste every 5 years or so and renew
This all depends, over sized component would work, if there is enough room. More often then not, larger Bi Polar Transistors require larger Base currents, so the preceding driver stage may have to be up sized as well.@peapvp If it is a known issue, why not switch to heatsink tape, or a heatsink clip, or a larger, less loaded component that doesn't require the heat sink, to keep the component in its thermal performance zone? Renewing heat sink material every so often seems like extra work at a minimum, but what do I know?
All the best,
2Pbfeet
