LED reverse light. Found a great replacement for $11 at Harbor Freight
dragonman
Mason city, Iowa
Fits perfectly in the stock location, is IP67, 12/24 V, mount width and through hole match the bracket on the truck. I took apart the connector on my old light and soldered the wires in so it plug into the truck harness just like the original.
Would it be possible to add a switch on the dash to turn this on with out being in reverse ?
aw113sgte
1,328
La Crosse, WI
Of course! However if you just sent the 24v to the same wire, the backup beeper would also sound (I've read they are on the same wire but I also don't have the wiring diagrams to verify). You could just use a diode to prevent this.
