Ls3rx7
- 37
- 13
- Tulsa, Oklahoma
Just curious why it would matter?You don't really want to make the substructure out of wood now, do you?
Wood is a tried and true substrate for custom work. Covering with fiberglass and then leather or pleather is a widely accepted customization technique.You don't really want to make the substructure out of wood now, do you?
To fit 42” tires and because it looks better imoThank you... then I'm reassured
Question about the exhaust... why relocate?
You dont need to pull them to check them, glow plugs just dont fail unless something takes them out.The glow plugs decided they don't want to work anymore. It's been low 20s° here during the day and around 5° at night. So it's beached until I figure out why they decided to quit.
Right now all I know is the start box does turn on the wait light, and is definitely doing something as I hear it clunk when the light goes out.
I did replace the GPs when I first got the truck. I thought they were legit, but now I can't remember if I used a metric socket on them. Guess I'll pull them and check em all, and check for power at the plug wires.
Yay
Batteries are new. Truck turns over quickly. Of course it decided to do this when it's frigid here. lolYou dont need to pull them to check them, glow plugs just dont fail unless something takes them out.
low battery voltage will cause starting issue, check battery health
Yes. Already in its new home.Is this going to the West coast?
iFinally got the next GMV project home (M1165A1WB3). Found a few things the Marines left behind...
Similar finds in my M1151A1….. 5.56 and 50cal casings and links. But mine were not blanks.Finally got the next GMV project home (M1165A1WB3). Found a few things the Marines left behind...
You guys found cool stuff I guess mine was just a base gopher vehicle no bullets just dirt, ants and a couple mouse turdsSimilar finds in my M1151A1….. 5.56 and 50cal casings and links. But mine were not blanks.
Enjoy!
