New HMMWV owner, didn't know the ways of jump starting....now have issues
moo
Wilmington, NC
I recently bought a 2007 M1097R1 and have been having fun. We had snow last week and I took it out for a drive and it did perfect. However after getting home and messing around with it I left the ignition switch turned on. Fast-forward a few days and batteries are dead. Being a n00b I attempted to jump start it without success. I then disconnected both batteries and put each on a charger and got them fully charged. It would turn over this morning but not start and block heater was plugged in. This afternoon I tried again with block heater still plugged in but noticed the wait to start light was staying on a long time. Went ahead and started it and it seemed to run fine but I noticed now the wait light is staying on even when running and the heater fan no longer works. Assuming I did damage by trying to jump start it and have seen some posts saying the start box is likely bad.... would that cause these issues?
20,307
Well, I wouldn't swear to it but I imagine that you may have cooked your PCB (Start Box). I suggest that you download the TM's (Technical Manuals) for your truck. Especially the -10 book... It will explain how the truck should be started - with delays required to restart if if didn't "catch" the first time.
We have a member here that sells a start box that seems to get rave reviews. There is another guy here that will explain how to rebuild the box that you have... Give either of them a look. Start box controls the glow plugs and they are pretty important where you live.
moo
Wilmington, NC
I disconnected both batteries and put each on a charger but didn't wait for full charge before attempting to jump start with a jump box. As of now the wait to start light either goes out quickly or stays on forever. When the wait light stays on and I go ahead and start it the battery meter shows in the yellow. Shortly it moves to the green and then the heater fan will operate.
Mogman
10,065
Papalote, TX
The alternator delaying charging is normal, it has what is called a soft start.
  • Like
Reactions: 98G
