Gas millage dropping down from 18 MPG to 15 MPG
Indyharleyguy
70
Carmel IN
Hi all my 1984 CUCV MPG has dropped for no apparent reason. I've replaced the air cleaner but not the fuel filter. I'm thinking
about taking a almost new fuel filter off a non working CUCV that maybe had 1000 miles on it before it was totaled and putting it on my running CUCV. I was wondering if that was a good idea or not?
WWRD99
1,838
York Pa
My experience with an old fuel filter. My son bought a 1009 last year...dragged it out of the woods. Sat since 96. When I pulled the fuel filter off the mount it still had clean red diesel in it. That being said it depends on how long yours sat plus if it had bio diesel in it. That can mold up. If you're in a cold area try some kind of dejelling stuff. All of mine jelled up with the 5 degree days we had. All took some 911 then ran fine.
biscuitwhistler37
1,113
Michigan
There's debate about failing glow plugs causing decreased fuel economy as well, I don't think it would be as substantial as 3mpg seeing as they're only supposed to kick on upon startup and something like 3 minutes into cold idle, but maybe. Check the wheel bearings as well, and "goofy" stuff like tire pressure, hopefully it's something simple.
nyoffroad
718
Rochester NY
Some of the above is dead on, it's cold outside. What happens to oil and grease when it get cold? It gets thicker, from the oil in the pan putting more drag on the oil pump to the ATF in the tranny and TC all the way to the differentials and wheel bearings. The cold also effects the tires and sidewall flex and that also can effect MPG, while all the above changes as the truck warms up one thing doesn't change, cold air is denser. It takes more power to push that square box through the air than it does in the summer, speaking of power winter fuel has fewer BTU's due to being treated. Most all are small minor changes but when added up make a difference, ask any over the road trucker.
Indyharleyguy
70
Carmel IN
Did you lock your front hubs in for driving in the snow? I agree about the filter not causing a mpg drop. There is more drag somewhere. Hubs locked, sticking front caliper, parking brake hanging on and similar.
Hi, no, this has been happening in two wheel high for a while now.
I will go ahead and buy a new filter just because I don't know when the old one was replaced, though
Sent from my SM-S908U using Tapatalk
Indyharleyguy
70
Carmel IN
Thanks the glow plugs were replaced a few months ago before I noticed the drop in MPG.
79Vette
157
Los Angeles/CA
I've never got more than 16 mpg out of my 1009.
It was as bad as 11-12 when I bought it, and with brand new injectors, IP, front and rear brakes and wheel bearings all properly adjusted, all new steering, ball joints and alignment it's in the 14-16 range now. I also have an SM465/NP205 and advanced adapters Ranger overdrive, 3.73 gears and 33" tires, and a 6.5 turbo.
MPG went up about about 1 when I went to the manual trans and about 2 when I replaced the injectors and IP, but all the other mods did not have any affect on economy.
I hear stories of people getting 18+ in these trucks but I just don't see how it's possible. If you do figure out a solution I'd love to know!
CARC686
610
Las Cruces, New Mexico
I would assume altitude reduces MPG, but I got an even 20 out of my 09 driving up and down the mountains. Flatland here is at about 4k feet. I'm running a HMMWV IP on a NA 6.2 with an open element air filter and turbo mufflers. I dump a quart of 2 stroke in with a full tank. Sounds like a lot, but a full tank is 108 quarts, so it's less than 1% and the IP likes it.
Edited to add it's overfueled with the HMMWV IP, which ought to hurt economy, but like I said, it reliably averages 20 MPG. Running open intake and exhaust made a big difference, no doubt. The intake is really loud. Sounds like a wide open throttle Quadrajet at all RPMs. The welded Thrush turbo mufflers are barely louder than stock.
79Vette
157
Los Angeles/CA
I'm not sure about OP, but I'm at sea level and I have a turbo. Still gets 14-16 mpg.
And I don't have any mufflers and it's terrible. The downpipe comes off the turbo and dumps right behind the passenger front tire because I haven't had time to make an exhaust, and it's the loudest vehicle I've ever driven. Including my 396 small block Corvette with side pipes...
