- 7,225
- 10,130
- Papalote, TX
If it has done that then I would expect your glow plugs to be blown.Yes, 25v idle and up to 27v running. How much time should the afterglow last? Till it reachea running temp of 180 degrees? Thanks
Your box is bad…24v for 9 seconds, after glow last 2mins, an S3 smart start sends a constant 5VDC for 2mins, previous start boxes pulsed 24volts for 2mins. If you have 24v after wait light? Your new plugs are now smoked.I have the exact same issue with my nartron smart start box even after new plugs. Wait light turns off and its still sending 24v to the plugs and never out of the yellow. I hear the clunk turn off when turn off the vehicle. Any suggestions?
New plugs were tost. Only lasted for 1 ride.There's a good chance plugs are toast. Just replacing them and could have more toast. These cold mornings coming up and there will be a lot of toast on the HumV table.
Other choices are pancakes, waffles or a muffin.
Make the call, CAMO
The underside of the bread board is probably destroyed. Look at the post above you, post number 85. That is your best course of action.Does anyone know what the part number for the blown diode in the attached picture is?
Thanks!
Yeah, I am ordering one from Cam too. His sounds like the end all be all for start boxes. Just wondering if I should get this one fixed as a backup.I just took the same off a working truck and replaced it with a camotek. 300$ of you want it. Going on flebay soon.
Nah, what you got there is a nice sinker.Yeah, I am ordering one from Cam too. His sounds like the end all be all for start boxes. Just wondering if I should get this one fixed as a backup.
