Funvee dead 😕
williamh
679
SanDiego Ca.
I think my control box died. Ran it on Friday and jumped my new Mep. Went to mone it tonight and dead , no lights - nothing. Jumped it with the Mep and still nothing. Got 28v and a good ground but not even the lights work. Looked around for a cb under the dash but it’s a little cold and dark. Any quick fix advice ?
TOBASH
3,844
Brooklyn, NY
Read my signature line.
Rebuild your box or contact me for other options.
williamh
679
SanDiego Ca.
A little follow up. So far pulled all wires in the battery box and cleaned. I don’t know what the MC has with silicon but what a mess. Nothing looked bad but cleaned it all up. Found the front battery is really weak , put it on a rejuvenating charger and gonna wait to see if it comes around.
williamh
679
SanDiego Ca.
It’s all just bad news 😣 , cleaned all the electrical and replace the batts. Lights are happy but as soon as I turned on the ing. switch , I can gear the fart box relay click than the wait light comes on for 1/2 second and everything goes dead. So hopefully tomorrow I can pull the box and look inside to see what’s up.
Milcommoguy
2,359
Rosamond, CA
Let me know what you see in there. Here one to study. Recent customer with no start condition. Something to do with the smoke was released.
No it wasn't in the LA fires, Camo
20,457
Missing the picture...
williamh
679
SanDiego Ca.
Here’s a little update. It’s good and not figured out. After cleaning up all the electrical and replacing the batts , nothing changed. After connecting everything back up the lights and everything would come on but as soon as I turned on the Ing. everything would die. So I re pulled the batts and wires then pulled the smart box. ( last time someone replaced it they put in bolts too long and stripped the nutserts. Had to cut all the bolts ) so I pulled the smart box apart and everything looked perfect. So I check all the wires and everything I could test looks good. All plugs look good and pins all check ok. Re install everything so I can start tracing a bad wire ? Now everything is working proplery 🤷🏽. Must have started it 50 times since then , no idea why it now works.
williamh
679
SanDiego Ca.
I’m sure you’re right. I just haven’t found found it yet. Being sick for a week and now raining doesn’t help the search. I’m sure it will pop back up , I’m hoping it won’t lead to a total meltdown.
TOBASH
3,844
Brooklyn, NY
One of my trucks went dead when I was driving it. Initially I was exasperated, and then I realized I had been working on the electrics replacing the protective control box with one of my genius boxes. When I checked my connections, turned out that one plug had fallen off because I did not completely tighten it.
Recently, another member here posted that his truck went completely dead. I asked him to check the same PCB connections, and sure enough that was the culprit.
When you take everything apart and then reattach, you can restore a connection that was either loose or corroded. You may never know exactly what was loose or corroded if the above is what happened to you.
NDT is correct also. Carry a tool kit in your rig.
Mogman
10,204
Papalote, TX
Had you re-seated the inside and outside plugs on the EESS box before?
williamh
679
SanDiego Ca.
No. I did check for tightness originally and there were very tight. I’m sure it will pop back up. I thought it might have been because the box was loose with the mounting bolts ? It should have been grounded threw the wire harness.
