HMMWV won't start, transmission light is on
scbean
Carson City, NV
We drove our 2001 M1123 HMMWV into the middle of nowhere on federal land and when we went to leave it won't turn over.
Getting there, no issues, every previous time has never had an issue with starting. The batteries are 12.7 and 12.75 so I do not think it is the batteries.
At first, turning the start box to run the wait light turned on solid for a few seconds and then turned off, as expected. Then when we went to "Start" it made some mild sounds (similar to how a car sounds with a VERY dead battery) and since then the only light that will turn on consistently (in any state, eng stop, run or start) is the transmission light in the "run" state.
We suspect a cable / wire was vibrated out of place since we have been driving it off road a fair amount since we got it. We tried tightening all the battery connections and there was no change.
Any ideas?
Thunderbirds
422
Northern Black Hills South Dakota
Any ideas?
Check all the major ground cables, AND the starter cable and ground. Make sure you wiggle any cables or tighten lugs ONLY with the ignition off. A sudden reconnection may fry components and most likely will create arcs and sparks...
The trans light should stay on if the engine is not running until it is started.
Good luck! Keep us updated.
scbean
Carson City, NV
The ignition switch is fine and getting 24V, just double checked. The trans light comes on but the break light and wait light do not. The wait light does not seem to get any power checked by a multimeter. They use to light up for a split second when first turned to run, but not anymore. You can hear what sounds like a relay just behind the battery compartment switching when you go from stop to run. The heater blower also doesn't have power, it use to run when you were in "run" mode.
Also none of the dash indicators do anything when in the run position. Anything people can think of?
Gcelevator
761
Fort Lauderdale, Florida USA
Hey there. Did you check your park switch (it is a 4 speed i guess) are you getting power to the starter selenoid? Probably your smart box went kaboom and is not allowing the power to ho through. Try also jumping out on the diagnostic port and see if it starts.
scbean
Carson City, NV
It seems like it is likely the start box, I am strongly considering getting a CAMO one since this seems like a VERY common issue with the S3 box, unless someone has a different suggestion. I spoke with the owner of CAMPO for a bit and replacing the box and possibly the glow plugs seems like the next move...
TOBASH
3,838
Brooklyn, NY
Read my sig line for DIY PCB/EESS box instructions.
Lots of happy rebuilders.
Milcommoguy
2,352
Rosamond, CA
Good talking with you on your start / glow issues. Sure, you can build one or buy one.
Just like a HUMMWV, CAMO
scbean
Carson City, NV
Batteries are fine, replaced the box with a CAMO box and no luck, the main guy at CAMO was super great and we were on the phone with him for an hour while he walked us through what it could be. He seems to think its a loose cable causing a ground issue. We checked all sort of cables and no dice although we didn't a multimeter (this time) so we can't be sure this time. Any other ideas?
Mogman
10,180
Papalote, TX
Get the schematic and learn how to use it and there is no issue you cannot figure out.
TOBASH
3,838
Brooklyn, NY
Shift into neutral and see if it cranks.
Shifter switch may be fried.
Go behind dash and check start switch wires.
Run a hot wire to the solenoid and see if it engages or is fried.
Check wire from PCB to starter/solenoid and see if it is energizing.
