Winch install ideas
Indyharleyguy
70
Carmel IN
Hey All. I have a BADLAND APEX 12,000 lb. Winch with Synthetic Rope that I'm going to have installed on my 1984 CUCV. I was wondering if I can see some photos of winch installs others have done. I plan on having it installed on the front tow hooks.
Also anything I should know about the wiring connections.
Thanks
sneekyeye
139
ALABAMA
I have a 12k Badlands winch, not the Apex. I mounted mine upside down, using the cut down Harbor Freight mount plate, to the upper frame rail right in the front. I cut a hole in the front bumper and put a fairlead plate cover one it. You really can't tell its there. I put the control box right near the washer reservoir. I did have to extend the wires, required additional purchase.
IMG_20220218_162247548.jpgIMG_20220218_162315058.jpgIMG_20220218_162332772.jpgIMG_20220218_162436863.jpgIMG_20220218_162445404.jpg
Indyharleyguy
70
Carmel IN
View attachment 940670View attachment 940671View attachment 940672View attachment 940673View attachment 940674
Thanks. I like the look like that just thought it would be difficult to do?
sneekyeye
139
ALABAMA
My major problem turned out to be getting a drill bit short enough to use a right angle drill to drill the frame holes. I had to cut some drill bits down really short and file the end down to fit in a 3/8 right angle drill.
I needed to source additional longer wires and crimp ends, but that was easy enough.
If you are competent and confident, you can probably do it.
