- 2,100
- 3,140
- Florence, SC
Subscribed for updates!
That’s what I am inclined to believe…How do the serial numbers work? I see 246 a bunch of zeros and a 4.
Is that the 4th truck off the line?
LOL it has been exactly 12 months since I got in in my shop bay….Life keeps getting in the way & kicking me where it hurts! I try to get done what I can when I can….Wow! If I could get that much done on my rig in one day... LOL
Subscribed! big project no kidding. Hope it all works out.
There were some flatbed trailers intended for this truck, but pics are few & far between.Awesome. was there not a sort of lowboy trailer that these used for aircraft recovery? regardless, great find and kudos on your plan and execution.
I appreciate the kind words and if you’re able to source something that shows the missing info, it would be much appreciated! I’ve searched through all the Austin-Western & M62 threads I could pull up in Search; I have downloaded copies of the 9-2320-211-35, but no specific info for the items I mentioned. I have also looked through Austin-Western manuals numerous times without success. While there is excellent information available for the A-W cranes themselves, there is no mention of items specific to the M246 apart from the crane assemblies.I can't get to the TM library for a few weeks but will check for outrigger info. If other TM requests come up let me know. We found more manuals for 5 tons in a wrecking yard and need to see what we have.
Tried the M819 manual? I believe it is the same body as the M246Items on the M246 I cannot find TM listings for (neither repair nor replacement):
- Crane cab enclosure (not including controls/gondola, those are listed), including glass, heater/defroster & hoses, fans, wipers, electrical;
- Rear fenders;
- Rear sheet metal (including mudflaps and mounts);
- Rear outriggers.
Many thanks for any help you can provide sir!
TM 9-2320-211-34P appears to be the AF and Army tech manual for the M246, M246A1 and 246A2. This TM covers what may be considered as depot level parts. Stuff that doesn’t normally get crunched or gets too crunched can be found there.Tried the M819 manual? I believe it is the same body as the M246
By chance would you have the TM # available for the 819? I haven’t been able to locate it… I’ve scrolled through so many thousands of pages that I probably overlooked it. Thank you!Tried the M819 manual? I believe it is the same body as the M246
Thank you sir! Yes I have all those, and they are all missing the sections I listed above.TM 9-2320-211-34P appears to be the AF and Army tech manual for the M246, M246A1 and 246A2. This TM covers what may be considered as depot level parts. Stuff that doesn’t normally get crunched or gets too crunched can be found there.
TM 9-2320-211-20P covers more routine parts that are always getting crunched in some manner.
TM’s 9-2320-211-34-1 and several other dashes cover maintenance on the M246, A1 and A2.
Hope this helps.
Thanks! The second photo is my actual truck, from the auction house that listed it.Did a little search on "Austin Western Company Crane" ......then hit 'images' .....and found one with some similarities.
https://www.thejumpingfrog.com/prod...-110-Hydraulic-Crane-sell-sheet-specs-ca-1960
View attachment 940732View attachment 940733
There was also a military reference so there is data out there.
https://collection.fletcherarchives...austin-western-truck-set-up-as-a-mobile-crane
I replied via PM to your manual info.I see it looks like you have the Zenith Carb. Much better than the Holley! If you come across the TM number for the crane, post the number, it might be in the library at the Museum. If it is, I can send it off to the printer for PDF conversion.
Will that little fuel pump keep up with the demand the 6602 has?
Nice job! These big ol pigs are tough to work on!
Looks like the air filter is missing. If so, want me to look in our inventory to see if there is one laying around?
