cstumpf750
- 30
- 13
- The Jersey Shore
I did a 1 hour load test with two 5kw 240v heaters I got from Amazon for $65 each. The thermostat is still working after it stuck closed on the first run. At the end of the hour, my oil pressure was 55psi on the gauge. With both heaters, I showed 76% load. An ammeter showed 34.5 amps per leg. No smoke other than on start up For a few seconds. I have a third heater coming so I can do a max load test. but so far I’m very happy with how it runs and performs.
